some of the others, but my pictures of the engine were moved to tech, injector pictures were moved to tech.. I understand you are trying to avoid a meltdown situation like before, but those were pictures and updates of what I am doing. I have seen a lot of other technical posts go right by - its almost like my posts have cought your attention and if they have any technical overtones, they are bumped. : *I* would be the one moving them over every time. Your vote is noted, and your vote is vetoed. If we went back to a single forum situation, then life would suck again. The two forum system allows a *lot* more latitude in what gets posted. You were here before we went to the 2 forum setup & you know what it was like back then. It was a primary cause of the meltdown last year. : I figured you would figure out that your posts belong in Technical because they are technical in nature....
My CarPuter Headquarters: [ ashleypowers.terrashare.com ] agpowers@bellsouth.net
